Occasional knock from n/s front
Hey all. I'm getting the occasional knock from passenger front. Only seems to be when I go up my drive which is very bumpy when u first pull in. What do you guys think? Drop links?
Drop links, less likely if only slight wishbone bush or balljoint. Having said that, my balljoints were very loose in their housing when I changed mine and were only showing a small amount of movement on lock when on the car.
Drop links, arb bushes, trackrod end, bottom ball joint, any of these.
Even suspension top mount as a minor possibility...
Edited by demonufo
Turned into a creaking noise and it's doing it on every bump. Going to look at it sat.
