Check your monitor refresh rate
Noticed recently the image on my monitor at work was shaking. It meant looking at it from a range of 6" to really see it, but I reckon it could have affected my general well being after a day at work. :)
One quick email to I.T and he said to check the refresh rate - Was down at 60hz, which he said was too low, so upped it to 85hz, and the wobbling has GONE! :D:thumbup:
As this could be a matter of health and safety in the workplace, thought I'd mention it up here. I accessed the settings through display properties, and advanced settings (using windows 2000 or something like that - should be similar for other systems ;))
Be careful if you have an old monitor because too high a refresh rate can put too much of a strain on it.
mine is currently set to 60 Hz for the following reasons
1) i run at 1280x1024 resolution and nothing less - it cant handle more than 60
2) i am trying to break my monitor so i get a TFT in its place :)
That old trick. Amazing that we have 2000-odd journos and associated publication staff at GHQ and they all seem to run on 60Hz without grumbling too much about headaches. I reckon they must all be on nurofen ;)
Indeed it can - a colleague at work made his monitor pop by running it at 85Hz! Might have been deliberate though so he got himself a TFT :rofl:
Chris
Well, luckily the monitor is only a year old - But the shaking was awful and the more you think about it, the more obvious it was. If I can blow up my monitor then never mind. :D 19" flat panel would be nice. :cool:
I think there's a Euro working directive that all monitors need to be at least 800x600 and run at least at 72Hz which is considered the ergonomic refresh rate.
I can tell when a monitor's 60Hz in about 1/60th of a second. Drives my head in and would need to have stock options in Neurofen :D
I must confess to running ym old CRT monitor at work on 120Hz.
I had to change it for a TFT last week ;)
I have always used 85Hz on my 19" Iiyama CRT. Dropping to 60Hz on that gives me a headache. My ViewSonic 19" flat screen TFT has options for 60 and 70Hz but I can't see any difference between the two settings and use 60Hz which is rock solid.
Noticed recently the image on my monitor at work was shaking. It meant looking at it from a range of 6" to really see it' date=' but I reckon it could have affected my general well being after a day at work. :)
As this could be a matter of health and safety in the workplace, thought I'd mention it up here. I accessed the settings through display properties, and advanced settings (using windows 2000 or something like that - should be similar for other systems ;))[/quote']
could have just asked him for a TFT. They dont suffer from the above.
:iagree: As soon as I sit down at a user's PC, even if their problem is nothing to do with the display, it's the first thing I change! Cannot fathom how it doesn't cause them serious damage or at least some diziness! :rolleyes:
I run 1280x1024 @85 on a 19" CRT at work. 1280x1024 on a 18" TFT at home, so the refresh will be whatever it's decided itself...
Steve
