Climate control - setting a default setting
Hi all, my fathers 62 reg Elegance spec Fabia estate has climate control, which is slightly different to my 59 reg.
Every time he starts up, the climate control system reverts back to 22 degrees and AC on. Mine doesn't do this, it simply remembers what setting it was on last time and you can then alter it accordingly. I don't run it on the Auto setting in mine.
Please could someone advise if the system in my fathers could be set so it remembers what it was set to the last time it was used or at least prevent it from coming on at 22 continually?
Thanks in advance :thumbup:
I'd say that's a fault. It should remember the last setting even on Auto. 22 is the default it goes to if you press and hold the Auto button.
Phil
Thanks Phil. :thumbup:
Edited by richardsfavorit
