Mk1 VRS clutch master cylinder
Anyone changed one?
Looks easy enough,but any hidden little problems?
Few drips of fluid have appeared on my carpet under clutch pedal :(
It's fiddly but easy enough, you'll need a pressure or vacuum bleeder of some sort.
Ok cheers.
Is that because it will be totally empty/dry?
As it bled up ok when I fitted new CSC just bleeding by pumping pedal.
Yes, I couldn't get mine to prime so needed the eezibleed.
Arse,ok cheers.
