Brake Light Switch problem.
Evening all,I hope one of you experts can help.
Is the brake light switch the same for auto transmission as for manual? (04 plate 1.4 BBY Auto)
I just had the EPC and Engine Management lights come on,but being close to home I ignored them and carried on. Its just as well i did because on getting home I stopped to unload then restarted to park the car only to find the auto box locked in Park, and no amount of stamping on the brake pedal would shift it.  I managed to reseat the wiring connector by reaching under the facia panel and luckily it started but now I don't trust the switch and intend to change it using the excellent guide on here.(Mr Haynes says I need to dismantle half the car!!)
  • Sponsor
Yep, looks like its the same across the Mk1. This  (item 1) is looking up for 2004. I think you'll get the same for any other year though.
Thanks much appreciated,I'll get one ordered.
I got a friend with garage facility access, to decode it and the only code showing was "brake light switch" so hopefully I'll get a cure.
