288mm uprated brake setup with 312mm option
For sale is my set of unused 288mm brake setup from an audi tt. The calipers are the ones from a 312mm setup but the carriers are for 288mm disc.
So you can run standard disc size but better braking as these calipers are alot better.
If you wanted to run this caliper with a 312mm disc you would just need the correct carrier.
I stripped these down and overhauled them before painting them black.
The passenger side has been fitted but car hasnt moved. A few small marks from fitting/storage.
Looking for £55 including brand new pads.
Which is cheap really..
Located in scun thorpe DN15
Phil
pm'd
You havent.. [emoji23]
These are for sale as i've gone a different route with brakes
have now...my bad :doh:
Are you able to post?
Sold
