312 Brakes - from Octy or TT
Which are the better brakes, the ones from the Octy Vrs or the 312 mm brakes from the TT? (Im fitting them to the Fabia Vrs). My concern about the brakes from the tt is that the calipers are not painted green!!!! not sure how i could get round this without it looking cheap!!!
So which ones are better, and where can i source a set? One guy on here is selling the 312 brakes from the TT but not sure about the calipers.
I should think they are the same as they are both 312mm but if you want to be totally sure, get the octavia ones.
They are identical bar the colour.
Hammerite smooth green is the answer to this, look perfect.
These are the TT calipers painted green with hammerite smooth green. Look OK from 6 foot away don't they? And even up close its hard to tell they're TT calipers painted green. :) I even just used a paint brush and the finish wasn't bad at all - best results can be obtained spraying the components though.
