Number Plate Lights
Both bulbs have gone out. Changed and still not working. Book doesn't help with which fuse. Any ideas as I need the car tonight?
Sent from my Galaxy S5
Sometimes it is a bad connection on the back door.  Clean up the contacts and see what difference that makes.  In any event I would just use it.  If you get stopped (unlikely) it was OK when you set off and you will most likely just be told to have it fixed.
Thanks Chris. I removed the holders bent out the connectors and back in. Refitted bulbs and all ok now. Must have been a gremlin
That is OK.  How do you want to send the £25 consultancy fee? :notme::D
I'll send it as.
Did notice one of the bulb holders needs replacing all cracked.
