Tilt steering wheel for Skoda Forman
Now that I have everything working properly, I would like to look into installing a tilt steering wheel in my 1994 Forman. Does anyone know of a steering column with tilt that is a bolt-in replacement ?? Maybe something from VW or Audi??
Also, I would like to replace the sheet metal grille insert between the headlights with something more custom looking. I can't find anything here in Colombia. Anything available in the UK ?? Thanks.
- JAMES
The only models you'd get the right length column from AFAIK are the Skoda Favorit and Felicia, or the VW Caddy.
As to a "custom looking" grille insert, I take it you want narrower edge gaps and/or something that looks/is attached to the hood?
Try making a template from corrugated cardboard, a male mould from wood, and then an insert from glass-reinforced plastic.
