Code Reader
Can anyone recommend me an error code reader please?  I'd love a VCDS, but let's face it - I'm only going to use it once in a blue moon and there aren't any features I want enabling, nor do I have any immediate plans to retrofit anything.
So, can anyone recommend a cheap as possible code reader that will help me diagnose my stuttering/hesitation issues please?
Cheers!
Cheers!
There are plenty of 'elm327' bluetooth OBD scanners on ebay - I think they work by pairing with your phone through Bluetooth (and on the phone an app to view the codes). I have never used these elm devices, so I can't say how well they will work in helping you find your trouble.
I think it's better that you find someone with VCDS near to your area.
EDIT: forgot to mention, there are many cheap hand-held tools available to read fault codes, but I am not sure if they will read DTCs from all modules like ABS, gearbox etc. Here is an example of one - link
Edited by GamesGoblin
Thanks. I'm mainly after it to see if the car has generated any codes that wouldn't trigger an EML.
Edited by planehazza
Thanks. I'm mainly after it to see if the car has generated any codes that wouldn't trigger and EML.
You should give the elm327 a try then - a listing I found on ebay
I havea  VGate scanner - http://www.amazon.co.uk/Big-Bargain-Store-VS450-Scanner/dp/B0063FPV96
Think I paid about £22 for it. No idea what it does better than the £10 versions.
It was handy for figuring out problems on the car. I hate going to a dealer/mechanic knowing nothing.
I should really sell it now I suppose.
I have a Gendan T55 - VAG specific.  A bit pricier at £65 but does the job and can access the VAG specific modules as well as OBD2 stuff.
https://www.gendan.co.uk/product_VAGT55.html
