Aftermarket Autolights
Hi,
My Fabia didn't come with auto headlights, only the DRLs that are legally required. I'd like to add the auto on feature for the dipped beams and I understand the way you do it is with the newer light switch.
If I ordered http://www.cars-equipment.com/www/en/shop/lighting-laser-logo-2/oem-5gg941431d-auto-headlight-switch-light/#prettyPhoto and fitted it, would it work with the Fabias system?
You're going to have to fit the light sensor to determine when they switch on as well. It may not be that straightforward either once you've bought all the parts, some VCDS coding will probably need doing also.
Sent from my Moto G
Id of thought itd be more of a pain and expense than its worth tbh.
Can see this being too complicated to fit, should just be plug and play
