Couple of intercooler questions
I've recently had a new turbo and I've been hit with the problem that most vrs users get (Boost leaks) on the standard setup
I was wondering what a complete budget intercooler setup with pipes would cost for my vrs
seen a couple of you have made your own pipework up off buying the bits seperate but I can't afford to make mistakes at the moment
also wondering if i could make up some pipework to fit the standard intercooler smic rather than having to buy everything at once
Edited by staykingish
The top one has been done diy so many times you should be fine sorting that, I've just got the bits and gotta fit mine.
On order to save costs I've got some large heatshrink to secure the bottom pipes until I get round to buying those bits.
Thanks mate think the one that is leaking the worst is the bottom one that goes to the intercooler by front bumper
one you can see if you get under car
sorry for **** explanations never been good at explaining things
Yep that's the most common one. Will let you know how i get on with mine..(should I ever get there).
I bought 2m of 65mm heatshrink, I would have bought bigger but it only place that had bigger was in China/Hong Kong. So hopefully that will fit!
