boost gauge help!
someone please help me, trying to fit my boost gauge, and i cant find a way to put the vacuum pipe to my egr delete from my drivers side vent, someone must no a way to route the pipe from drivers side air vent!!
I beleive there's a gromet or something if you take the glovebox out.
If you want it to go straight through the driver's side you'll have to drill a hole and use your own grommet like i'll be doing pretty soon.
Otherwise it's across the engine bay to the passenger side and back again.
Pull the wipers off and the scuttle off and loosen the wiper motor, this will reveal a grommet on the drivers side which comes out behind the dash under the steering wheel. I'll hunt out a pic and reply again shortly
Unbolt the wiper mech and motor and pull it up
It will reveal this grommet, the grommet you want also has the bonnet release cable going through it. It doesn't go outside the car so won't leak water either.When it's pulled out it gives more room to slot the wires and pipe through. Either drill the grommet, or squeeze it through the bonnet cable bit (has plenty of stretch)
Comes out behind the dash on the bulkhead which can be easy to reach from under the steering wheel area
Edited by mattievrs
That's great thanks! I'll use this when I do mine..
I gave up looking for a grommet so was just going to drill my own.
Comes out behind the dash on the bulkhead which can be easy to reach from under the steering wheel area6decc212.jpg
Wish I knew of this before did mine :(
