Lighter fuse/relay
Which number fuse is the cig lighter and the relay?
Conflicting advice on the two diagrams i have found. One says the cig lighter is 38 and the other says 41. Having tried both it has so far not solved it. 41 had a 20a fuse which makes me suspect its not that one as the cig lighter should be 15a. Also it says the relay is fuse 1 however the diagram on here says that is washer jets??
Any help would be appreciated. Thanks
Hatch or estate?
Hatch
Should be fuse 1 for relay and 41 for actual lighter - do you have the rear window lockout on?, Have you checked you have power to the wiring?, could be a duff lighter socket or element.
Checked everything except the power to wiring as i cant be chewed with removing the centre part to access the lighter lol
Just remember locking the rear windows stops the cigarette lighter from work... For some daft reason
Yeah that doesnt work anyways. Doesnt lock the windows. Just in desperate need of the lighter socket to work lol
It really is not that hard to lift the console far enough to access the lighter socket for diagnosis or renewal, it would be worth considering as your next step.
Maybe the rear window locker has something to do with it?? Just a thought
Yeah looks like thats my next step then cheers for the advice lads
Just bought a 10amp fuse for fuse 1 and it wont fit. Just keeps falling out. Any ideas?
Picture of your fuse box connections so we can comment further?.
