dashboard lights advice please
Hi we have a skoda fabia 3 auto petrol 2008. Lastnight the EPC and car skidding light came on and wont go off. Am after advice on whats up.... cheers! Have a photo but unsure if i can post pics.
Fabia 3 ?  2008 ??
If it's really a Fabia 3 (2014/15) then it sounds like a dealer/guarantee issue ??
Its an 2008 one
Welcome to the forum.
Maybe a Mod can move your question to the Fabia Mk2 Section.
george
You have a mk2 Fabia. The pre-facelift mk2 Fabia trim levels were 1, 2, and 3.
This should be moved into the Fabia II forum.
Ideally you need to scan the car with VCDS, as a number of different faults could cause that light to come up.
Find a local member with VCDS below, there a plenty dotted about the country :)
http://www.briskoda.net/forums/topic/262215-list-of-vcds-owners-previously-known-as-vag-com/
Edited by softscoop
Ahha. Over the Fabia writing on the boot it has a number 3. My mistake!
Does anyone on The Wirral have a reader??
There are a few members not too far from you. :)
Thanks! Hopefully they read this and we can borrow their reader thing...
We changed the brake bulb a few months ago- but recently its gone again.couldd.tgus cause the dashboard warnings? Think there maybe a loose wire or dampness in brake wire area for it to keep stopping.
Got a photo to help us a little? ;)
Although the car as if it's "skidding" sounds like traction control.   Maybe a sensor.
And the little 3 at the top of the Fabia badge is the "spec" if remember correctly.
Is this what your's looks like from the front?
a>
Edited by Naths vRS
PM a member local to you with VCDS and ask them to do a scan.
A number of different issues could cause those lights to come up.
It could be something as simple as a fuse blown.
