How do you change door mirror glass?
My driver's side door mirror heater element hasn't worked for some time now so I got myself a replacement item from ebay (a bargain at
Just clipped in. Turn the mirror glass all the way towards the car. Then push down on the side nearest the car ands get your fingers (if they're small enough) or something wrapped in a cloth under the otherside and prise it off the clips. If you look at the new mirror this will give you an idea how it's attached.
Once unclipped just unplug the heating element supply and then reverse the procedure.
