Turning off my engine management light.
Any help will be appreciated.
Without taking the negative off the battery does anyone know how to turn off the engine management light please ?
I've had a few issues but after cleaning the egr everything is good again.
53 plate Octavia 1.9tdi.
Welcome
It all depends what has caused the light to come on, there are numerous possibilities.
You really need to get the car scanned with VCDS to pinpoint the problem, you can fine a map of VCDS owners in my signature.
Thanks for the prompt reply.
Does anyone know if those code readers you see on eBay are any good ?
I am assuming they reset the fault.
No point clearing the code until you fix the actual fault otherwise it will be back
Update , after cleaning the egr with egr cleaner from halfords the eml is no longer on and the car seems to be back to normal. Fingers crossed.
