Wheel bearing
I am about to purchase a fabia vrs 55 reg but both front wheel bearings are worn.
I am hoping to do them myself I do have access to a press but the question I want to know is do you have to remove the abs sensor from the hub?
You need a special type of press for these,not just a normal press.
Alexe3 has done his recently,he'll tell you the type of press required :)
Gen 2 tool or somthing its called.
make sure it is bearings and not just tyres or a damaged gearbox/diff
Just found out it's the tyres so getting them replaced
nice easy result :thumbup:
Get the tracking done +check your bushes on the console - mine where the culprit
