Oil use all of a sudden
I had to top up from just above bottom notch on the dip stick, 2 months since last oil change..i check the oil every 2 weeks, so this has come all of a sudden. No signs of a leak. or blue smoke. Turbo  has done less than 5k, same as intercooler.
This seems to have happened as the temperature outside has dropped.
I have noticed a slightly noisier engine on idle.
Any suggestions?
Edited by FromTheDarkness
Are you getting any extra smoke at all?  Loss of performance?  Could be turbo seals even thought its fairly new,
of course the other thing could be the bottom end is burning it, but would hope that would show itself in other serious symptoms.
No mate every thing seems fine, in fact not even a wisp of smoke since fitting the hybrid, i can tell my back is always clean  - so to speak. But maybe its hidden as hybrid is under powered atm with stock map.
I had that problem last year (no turbo) just a sudden dip on the oil level in colder weather... hasn't happened again (yet) I put it down the to cold weather n forgot about it until you posted this...
But where can it go? :D
Burned it
Been under it today, theres a lot of crap coming from the oil breather pipe (elephant mod), its all been splatted to near the back off the car... also i have a weeping sump plug.
