Handbrake Adjustment
Does anyone know how to adjust the number of clicks to hold the handbrake on 2011 pre face lift model / I've recently had new pad fitted all round but the handbrake still requires adjustment.
It should adjust itself automatically. After I replaced the pads and disks, the first time I pulled the handbrake the lever was a little high even after pumping the brake pedal to get the pads to the right position. After a quick test drive the handbrake was back to the correct position again.
Yeah, give it a day or so of normal driving and you will find it tightening back to the usual position without the need for any manual intervention
