Centre Arm Rest
Oh dear!:thumbdwn:
Looks a bit CHEAP! (about
How about a genuine Skoda one? :confused:
Should have change from
Doesn't the armrest make using the handbrake a real pain? I know it does on the Octy 1 :D
Chris
If you can lift it slightly. It should be OK
Chris
I find it's not so much the handbrake, as you can loop your arm round the armrest and yank it. It's the seat belt which is a pain because the armrest storage box is exactly where you need your hand to be to do up the buckle. My armrest spends a lot of its life swung up out of the way, and really only gets used when cruising.
Looks like its more trouble than its worth !!
No problem with the handbrake here either. I find you can just bend your hand under the armrest and apply it. No problems with the seat belt either.
My armrest spends all it's time 1 click from as low as it can go (slightly below horizontal). I find this way, you arm rests on the armrest (funnily enough!!) and your hand is at the correct level for the gear lever.
I love mine!!
