Turbos (HELP!)
any turbo for sale around York? closer the better. need it asap
also how do i tell if a turbo is good or not?
new to this stuff haha sorry!
I would suggest typing 'Turbo' and 'replace' into the search bar and having a good read through :)
Xman may be your best bet for a fresh one.
JRJG
Check if there's play in the shaft. There should be slight movement but hardly. Check the conditions of the compressor/turbine.
A used pd150 is a cheap and good upgrade. Almost a direct bolt on too.
+1
I thought suggesting a Garrett pd130 over a replacement kkk turbo would be a good recommendation too.
JRJG
