Replacing Screen Washer Pump - how?
The pump on my screen washer bottle has started to leak (see picture). I've order a new one but I just have a quick question: how does the pump disconnect from the bottle? Does it just pull off or do I need to twist it off. I dont want to damage the bottle taking it off.
Thanks.
Just give it a pull iirc :)
OK, thanks. Seems odd that it's just a push fitting. I would have thought that kind of design would leak fairly easily even with a seal.
The bottle is curved so it takes abit of force to pop it in and out, it also has a large thick rubber seal. It's never under pressure so doesn't leak.
