Fabia 2005 electric window raise and lower fault
My fabia 2005 front windows have stopped working I have checked the fuse and that's ok, the door lock switch at the front of the switches is working can any one advise me on what to check and in particular on the pins underneath the swiches (power in power out ) so I can test for supply in and out or anything that can help
you've posted this in Fabia 2 rather then Fabia 1. Might be better to move or re-list it. The Fabia 2 has different switch as door lock switch is in centre console, not on door switch.
