Brakes - Eurocarparts - Help
I'm somewhat confused about quantity etc of each item and just want to confirm it.
I have typed in Fabia 1.9 VRS SE and these were all in the selection so I'm hoping they're right.
Apologies in advance for my incompetence, I can do most things on my car but my dad usually orders my parts because he gets discount from motor mania on trade but they said £66.97 for front pads, rear disks and pads - If I've got this right, these here are under £60 and brembo is a good brand for brakes iirc, rears are just cheapest ones but 'eicher premium' sounds german, and adequate, haha!
My current brakes are working fine but they're squealing and my rear disks and pitted. As I said, still work fine so not interested in upgrading my brakes at the moment, I'm just replacing them because I'm fitting springs and dampers in the next 2 week so I will do this at the same time.
EDIT - Well putting it in my basket confirmed the disks are single because it came up with a notification reccomending getting a pair of disks to fit at the same time, non for the pads so that's the pair.
Can someone confirm they're the right parts?
11.44 rear disk - 232mm 9mm is the correct rear disks right? Says fitted quanitity 2, yet says (priced per disk) can anyone give me some clarity on that, do I order 2 or 1 pair?
10.26 rear pads - Fitted quantity 1, but it says priced per AXLE, meaning both rear wheels???
Am I to assume the same goes for the front brembo pads?
26.20 brembo front pads - Fitted quantity one, but the picture clearly shows 4 pads (2 wheels) The pads obviously need changing at the same time so am I to assume it's fitted quantity 1 PAIR? I just saw priced per axle as well so surley?
Thanks guys, sorry for being so annoying.
Edited by AdamOP94
The pads will deffo be a car set,so a set of four as you should never just change one side.
Those discs are priced each,so order two.
Yeah I figured that when I added them to my basket haha!
Do those measure up correctly?
Never had standard front brakes sorry!
Rears are deffo correct,discs too.
Front state 'for Lucas' so as long your front calipers are Lucas they are correct?
Those front pads are correct.
"For 288mm Discs, Lucas System, Without Wear Indicators"
Cheers guys.
My dad said motor mania are getting in a brand called Moprod which are apparently good.
For 66.97 or is the eicher tears and brembo front pads better for 6quid cheaper?
I like using Mintex pads,just the standard road compound,they are not expensive and Mintex are a long running decent manufacturer
