Drivers Side Central Locking issues
Hi guys after some help please!
My vrs (SE 2007) has developed a problem with its central locking on drivers side door only. It started about a week ago, when unlocking via remote it would unlock all doors except drivers, locked the car via remote then unlocked again and the pin came up. However now it's getting so much worse, trying the key manually does not help at all same problem. If you hear the door from inside it sounds like something working quite hard to try to unlock. My question is this likely to be the motor in the drivers side door and if so is it quite easy to resolve?
Cheers,
Niki
You will need a new lock mechanism. About £120 brand new or £25 second hand of eBay. None genuine ones can be problematic and can result in weird sync issues with key fob locking.
The new lock part number MUST match your current one exactly.
Thanks very much I'll get looking :-)
