Check lights warning on dash
Can anyone help ?
This only started last night when I turn the ignition on it asks me to check all my lights, it list most of the lights dipper beam, indicators, rear fog lights and so on it also mentioned my parking sensors.
My front passenger head light wasn't working as well as others but after a few minutes the drivers side started to work again along with other lights.
Any ideas ?? Thanks
Could be the connections are dirty?
Maybe some electronics + water problem?
Have you checked the CCM module?
A dodgy bulb can cause the sometimes overly sensitive bulb-warning system to have a panic attack.
If one of the dipped headlight bulbs was off but it now back on then I'd start by replacing these (always replace in pairs).
You also mentioned a few other bulbs had blown?
It sounds like the cars lights need a bit of TLC.
I'd be spending the £20 or £30 and replacing all the bulbs for brand new ones as a cheap starting point.
