Fabia MK1 Components
Been searching the forum, have read the front speakers can be tight for mountain depth. Going to fit some JBL CS-6C, they have a 59mm mountain depth so will I get away with some MDF 18mm / 3/4" spacer/baffle?
How difficult is it to get speaker wire into the front door's and also where is the best place to run power cable to power my amp?
Sorry for the simple questions, just trying to get a head start in between this rain.
My setup will be:
Pioneer Head Unit
JBL GTO 3EZ Amp
JBL CS-6C Components
JBL 8" Sub x 2 sealed.
My setup will be:
Pioneer Head Unit
JBL GTO 3EZ Amp
Best place to run power cable is the hole behind glovebox i believe.
The grommet is in the scuttle area. It's where the bonnet cable is on the left hand drive vehicles.
The easiest way to run cable through the a pillar is to disconnect the door harness. Then unclip one of the connectors from the frame on the car side. Pull that back into the car, then when reconnecting pull the door loom through into the car. This means all of the wires will be connected but you will have a vacant hole to feed the wires through.
