Skoda Audience Mp3 no backlight
Hi all.My backlight doesnt work on my audience mp3 on ma mk2 Skoda Octavia.Only get it around the volume button.It could be annoying at the winter when its always dark.
Any suggestions would be great
Nobody??????
It's probably either a LED or the power circuit that powers them that's failed. It'll need taking apart, the fault finding and fixing by someone that knows how to.
Easiest option is probably to replace it with a different unit as I expect a repair will probably be around £100 looking at similar repairs on instrument clusters.
That's great thanks for the advice.Do you know how many led lights are inside for the buttons and the screen.how come the volume button backlight works ok.
No idea how many LED's or what size are used in the Audience I'm afraid. Unless either you or a friend have the skills to do it, the unit's probably not worth fixing.
Depending how they've wired the LED's up, the volume control may have a different power source to the other buttons. It's impossible to know without seeing a PCB and following the traces.
hello zolo did u find solution of audiance mp3 no lights
Hi Iakhwinder.No not yet im gonna try to do a software update first hopefuly it will solve the problem
