Installing a subwoofer
Hi guys and girls just wondering if anyone can help me. I want to install a subwoofer in my 2007 octavia vrs it has a bolero head unit is there a way that I could use that head unit with the sub and how.
Sent from my SM-G925F using Tapatalk
There will be a way and it might be using something like this
http://www.ebay.co.uk/ulk/itm/261278273918
Not sure how you would sort out the remote switch
Would need a thick power cable and earth fitting also
Thanks I've already got the the power cables and stuff and just ordered the converter off that link. Just need to find out what to do with the remote
You might want to consider a different convertor such as these:
http://www.caraudiodirect.co.uk/accessories/line-output-converters/phonocar-5-142-line-level-converter-inc-remote
http://www.caraudiodirect.co.uk/accessories/line-output-converters/vibe-matrix-delta-box-car-speaker-wire-to-low-level-rca-output-line-convertor-4400
No idea of the quality but both include a remote wire for the amp. The more expensive one seems to be exactly what you need :)
Edited by langers2k
Do you know where it's needed to be connected to?
it uses the output from the speakers
Just be aware that some are designed to replace the rear speakers whilst others can be used in parallel with them.
you can get models which have a remote and sense voltage through the speakers to activate the remote.
Alternitavely you could fit a switch or use an ignition live and a fuse tap from the fuse box at the drivers side of the dash
