256mm rear brakes
Do the people running 256mm rear brakes have different back plate/shields to accommodate the different discs?
Most people just bend the original one away or cut the lip off it.
You can change them for the octavia ones if you wanted but it's quite alot extra work for what it is.
I just bent mine like mentioned above, much easier as otherwise you have to separate the hubs. cant even see them once the new disks and wheels are back on
Andy
I just chopped the lips off mine.
Thanks for the replies :-)
Sent from my SM-G901F using Tapatalk
