Rear hub size 30 or 32mm?
Hi
Anyone know what size rear hub an octy pd 2.0 pd 140 takes as one of my abs rings on the the hub is faulty. Thanks
If memory serves it is a 12 point 30mm socket that is required. And they go up chuffing tight.
Sorry I was referring to the bearing size as I read there are two sizes for golf mk5 wonder if it was the same for the octy as Euro car parts seems to just list a 32mm one.
  • 2 years later...
hi did you find out was it 32 or 30 mm  ? ..i same situation 2008 oct estate 1.9 tdi
