Climatronic Hidden Menu mess...
Greetings, i may have accessed my climatronic's hidden menu and i also may have messed up some of the values.... like really bad.
Now is this something that might be damaging the vehicle in any way?
Also is there a way to bring back the factory settings?
Edited by Unholyvamp
I thought all you could do is display various things, you can't change anything?
Sent from my D5803 using Tapatalk
Didn't even know there was a hidden menu
The question still remains.... how do i reset it
It shouldn't be possible to change anything with that menu. All it does it read out various bits of data.
Did you run the climatronic reset procedure by any chance?
To do that, press the face direction and Econ button at the same time.
All that does is run all the flaps through a cycle to reset them.
I was going through channels and subchannels that i know for sure.
But then i read somewhere, that some of the values can actually be changed.
I'll try the "face direction + Econ" reset procedure.
Thanks again!
