dimming mirror rear octavia 2014 problem
Hi :
i have a Octavia Elg 2014 and dimming mirror rear stop working any idea what should i do . is there any fuse for it ?
thanks .
When you hit the button to turn on the dip does the green indicator light come on ?
no. it does not working . there is no green light and i can see the mirror is not working .
Edited by shahin
I would check the fuse next:
It uses fuse no. 34 as far know. On page 225 of my my16 Octavia manual.
i had checked it all is ok .
For my Elegance 2013, Page 266 of the manual, Fuse # 34, but it's shared with ASR, ESC, TMPS, back-up light, phone équipment and some air conditioning sensors, so, if it was the fuse, you'd see à lot of things going weird on board :-)
Could be the power button, a cable disconnected. Make a test : At night, turn on the engine and the main beam, turn on the mirror by pressing the on/off button, check if the green led light comes on, use à flashlight or your phone's led flashlight to illuminate the mirror's sensor. it should dim quickly. if not, it would be a dealer job.
there is no fuse call 34 in my fuse box
Edited by shahin
If the light doesn't come on in the mirror take it in to the dealer. Simples. That is what warranties are for.
Sent from my HTC One_M8 using Tapatalk
the warranties is out that way i am trying to find solution for it .
Can you see if there is power getting to the mirror?
Sent from my SM-T710 using Tapatalk
Car is a 2014. Does it not have a 3 year warranty?
in Denmark is only 2 years .
A January 2014 car then?  Try it - if it's failed just days out of warranty, they may honour it..?
