Front grill removal..
Managed to get it all loose - how do you get it past the bonnet release lever? Is it a case of taking that off? Surely an easier way that I'm overlooking..
It's only a nut to remove it,iirc you do need to.
I read a guide on here that mentioned it was just the 4 torx screws and it pops off.. it certainly didn't. It was 8 torx screws.. and I'm stood there with it flapping around thinking I was daft as I couldn't figure out how to get it past the lever.
That was the only way I could see possible. Cheers Kev!
you can just remove the 4 torx screws on the bottom half.
As for the bonnet release it does need to be removed, 8mm nut.
Depending what part you want removing you could just unclip the chrome bit while its still fitted.
Ye I've got it off now fellas - top notch :-)
