Cleaning EGR and Throttle Body
I'm thinking I would like to check and possibly clean my throttle body and EGR.
It's a 2.0l petrol automatic from 2002. Used for lots of short journeys and holiday trips away.
Getting a bit rough on idle. I imagine after so many years it's all getting a bit gunged up.
Has anyone got some good guides/tips on how to do the 2 jobs? Which one would be more important/beneficial?
Thanks in advance.
Many thanks Dean.
A couple of people mentioned if you disconnect the battery first you should be able to disconnect the throttle body without having to reset it after with VCDS.
Is this true?
  • Administrators
I believe so but I didn't want to take the chance so I turned the ignition on and got someone to press the pedal so I didn't have to faff around. That's what I'd recommend.
