1.8T 4x4 Spluttering, Had sunroof leak
Howdy Folks
So this is now my second 4x4 elegance, when i bought the car it drove and started fine, no issues other than an eml and mentioned that the sunroof doesn't open fully, that i noticed at that point in time, but the next morning when it started it fired up right away and started to splutter, was getting noting from the throttle pedal off and on again with the engine and started to get some throttle, later that day i noticed my drivers a pillar at the roof lining has a wet patch, so i begun to wonder if it was the throttle pedal getting wet, which made sense to me, so stuck the blowers on the feet and later that day no issues, so yesterday i took the roof lining off to be confronted by my suspicion that there was an issues with the sunroof, so checked the run off pipes all were fine except the drivers which seem to be blocked so used some solder wire and poked it down it and gave it a blow through, solved that part, so replaced the sunroof since the other was sticking, and so far that leak seems to have subsided, but this morning i got the spluttering again, so i think i might changed the pedal,also something else to not the boy said the obd port wasn't working :S anyone clued up on what wire go ware as he mentioned something about pin 13
