Speedo Cluster
Afternoon all.
Can anyone tell me if its possible to just change the speedo cluster on a 52 plate Fabia or does it need to be linked to the ECU?
Cheers.
Colin
It's locked to the car, so you need the 4 digit car code and the 4 digit cluster code to make it work. The car will be immobilised unless it's all coded in. The cluster code is on the cluster (obviously) and you'll either have the car code on the factory key fob or you'll need to get someone to read it out for you with a software tool.
read this
You can have the immobiliser removed from ecu
Do you mean totally disabling it?
You can disable the immobiliser but for the money that would cost he could just recover the car code and get it programmed properly.
Speak to EddieNL he did my golf
yeh
depends who you know but yeh as above always better to have it programmed to car
Edited by steveopc
yeh
For a man that's had his car stolen you make some ridiculous suggestions! Fabia isn't exactly a fortress to get into as it is
hmmm yeh stolen with the key like anyone if they got your key they got your car and its got dead locks and you can't bend the door like a saxo so its pretty secure also I have a cobra anti jack alarm on mine didn't say to do it but said it can be done
If the OP is in Derbyshire then Shark wouldn't be a very long way away - they're in Mansfield.
