Seat memory not working
1 hour ago, deepshegde said:
Looks like hardware issue than software. Dealer shud be able scan and tell you whats wrong.
I have a 2016 model with the same issue, the dealer has checked it all through and it appears to be correct but the scan report shows no basic setting stored. They have gone through the resetting procedure without success. They have submitted a report to Skoda Technical Dept and they say it should be working but its not. Works perfectly OK manually.
  • Replies 50
  • Views 63.6k
  • I had the same problem when cleaning my car. When moving the seat all the way forward it stops. I double checked it was all the way forward by moving the switch again and it moves half an inch and sub
  • Jeez, do i feel like an idiot!!  My problem was user error.  I looked at the instructions, read that you have to press "Set" and within 10 seconds press the number you want to store that setting under
  • Graham Butcher
    Graham Butcher
    I had the same issue with mine, and today I took it to my service agent who had a look and said that it needed a software upgrade, which he did, and now the seat memory is supposed to be working, so I
