Final plea F.A.O. VCDS guru(s) only
Polite request...
Tried asking this a couple of times now, but haven't managed to get a definitive answer; also messaged local VCDS guy from the VCDS a few weeks back, but no reply as yet.
Dealer says it's possible, and that the coding exists, but that Skoda UK won't provide them with it, so.....
Can I, or can I not, have a pair of (H7/LED DRL) SEL headlights "coded" to my SE, using VCDS, and is anybody willing to assist me in doing this? I'm told that the plugs at the rear are the same.
Edited by 2014FabiaSE
Polite request...
Yes it is possible. You just have to know to handle VCDS, some basic technical knowledge of cars and tech terms + really good German. If you have all the above you will manage it by yourself, if not just ask the local Guru and be the first to do the retrofit.
Sent from my SM-G900F using Tapatalk
Polite request...
Check that the plugs are the same, my MkII Monte with the projector headlights had a twist fit plug for the H7 bulbs but my MkIII SE with standard headlamps and H4 bulbs have the fiddly wire clip fittings, just a thought that's all.
Would really like to have that aswell. Where would you buy the headlights. Havent seen them around yet.
My local VCDS guy hasn't read my message so clearly isn't a frequent visitor to the forum. Can anybody else in Yorkshire or Lincolnshire assist?
Did this retrofit in Denmark
8af077ebfc23f917e13ee57e86f90dec.jpg26187330b988539af8e63a1faeb3a074.jpg82a6c646fc88248383043b075f8a7c23.jpge74a713782e914659084d37bb6b0b142.jpg
@fayers
Great to see another one from denmark :)
How much did it cost you?
Bought the lights on ebay for about 140 euro. So very cheap.
Could you share if any coding is needed and if all the cables are plug and play?
