Octavia 2 (2004 -2013) Heated Washer Loom for Heated Washer Jets
still 1x available
PM if you are interested
If I wanted to see if my car has heated jets or not, what would I be looking for?
Pull the nozzle jet out of the scuttle trim
Normal non heated only have the pipe connection
Heated ones will have 2x wires coming out of the underside of the nozzle
Thanks Eddie, I'll have a look at the weekend.
Eddie, what models are likely to have them as standard then cos pretty sure my very end of line '58 pre-fl L&K doesn't have them and I can't think of a model in the pre-fl range that's likely to be fitted with them more than mine?!
Well, hush my mouth! Was reconnecting the battery after working on the motor today and remembered this thread so had a quick glance... turns out mine DOES have it as standard, if the cabling and large blocks on the washers are anything to go by! :D
