Wheel spacers?!?!?!
Ok so i bought some of these
http://www.ebay.co.uk/itm/Hubcentric-Wheel-Spacers-Skoda-5x100-57-1-20mm-with-longer-bolts-/231483051068
Not the 20mm type but the 12mm and also not from this seller
These fit the stud pattern BUT they will not sit flat against the wheel hub!?!
These are well made but I cant seem to get them to sit right?!
Also the bolts i have been supplied are the 'cone' type bolts and not the bolts for standard fitment wheels
Gutted really as i was all set it have these fitted this morning:(
  • Sponsor
Sounds like your hub lip is too big for the spacer size on that particular brand of spacer. Do you have a picture showing the problem?
You'll need to change the bolts for radius ones as well.
Damian @ DPM Performance
Erm I will try
But I think your 100% right the hub sticks out too far to allow the spacer to sit flat against the wheel hub
Holes are right and the wheel bolts are just come ones :-/
Just been told by the company I am to return them and get a full refund so I am back to square one now :-/
Think they should be 57.1 diameter on the hub
The diameter of the hole is fine seems there's a little lip along the inside of the spacer which isn't allowing it to sit flat against the hub :-/
  • Sponsor
We have spacers available that will fit if you still require them although they are more expensive then the ones you purchased.
Hit me with the price then ;)
By eck Paul you must have deep pockets ;)
Short arms I believe, he's a Yorkshireman
Nowt wrong with being a yorkshire man;)
There's nothing wrong with that!!!
When God made Yorkshire he was just showing off!!
What was he doing when he made Geoffrey Boycott? :notme:
Making Geoff's brother, Jesus   :yes:
If I fitted Geoffrey boycott what extra width would I get as I don't want more then 12mm ;)
  • Sponsor
H&R 12mm with bolts - £90.25 delivered
  • Sponsor
If you could fit 15mm we have the FK spacers with the bolts for £65 delivered.
What bolts do these come with as I have standard wheels and will need the non cone type?
Whatever width it was, it'll be correct, it's Geoffrey, he'll tell you so. :clap:
Edited by nickgpfc
  • Sponsor
We can supply with either but if you need radius then they'd come with radius.
