How do i raise the xenon on my skoda RS?
Can someone tell me how to raise the level of the xenon headlamps from the default factory settings?
is it possible to do so using the VAG-COM? If yes can you tell me the codes required for doing this.
The guy at the skoda dealer said that the lights can be raised manually, i'm guessing he will try and raise the housing with levelling screws, but then wont the xenons adjust back to the same level? Also i'm not too enthusiastic with him fiddling with the lamps with just his eye as an instrument for measurement.
Do a search mate. Already a few tutorials on here.
You can adjust them manually, but they will revert back to the factory settings once the ignition is off.
You have to plug in VAG-COM & set the lights into adjustment mode, wait 30 secs then adjust them as normal & the select Learn.
This should keep your settings.
More detail here:- http://www.ross-tech.com/vag-com/cars/xenonalignment.html
Forgot to mention that I had mine aimed to proper MOT garage instruments.
Thanks Jon....
You're welcome. ;)
