Exhaust Gas Temp Sender Problem P242a
Hi All,
Using my new MaxiScan MS609 OBD11 after getting the following problem,
( I've had a series of Glow plug light flashing problems )
( Turn off the Ignition and back on Glow plug light goes out for some time )
I have found that I have a malfunction on my exhaust gas temp.
Sensor. Fault code is P242a. Bank 1 Sensor 3.
Sensor. Fault code is P242b. Bank 1 Sensor 3.
All internet discussion point's to the old 03L906088DE
( Before Diesel Particulate Filter )
Two updates for this part New 03L906088GR and 03L906088FG latest model
I am looking to update but have now seen more wiring problems in the same area
I will try and attach pics for viewing Problem Area.
Will keep you updated on how I get on after parts arrive and hopefully I solve the Problem's
Newbie
:D
I forgot to say that my car is :-
Skoda Fabia 1.6 TDI Elegance 2010 ( 26,000 miles )
I hope the Pictures work :-) ?
059 906 051C Diesel Particulate filter Pressure Difference Sensor.
Skoda Fabia 2010 Fault Code P242b
Skoda Fabia 2010 Fault Code P242a
Newbie :-)
Ordered a workshop DVD disk to find what I need to remove to get at the part in question.
Not sure if I can reach from the top ( engine department )
or I need to attack the Sensor from under the car lol.
Will put pics when I start the job.
Regards
Newbie :-)
I have now changed the Exhaust gas temp Sender.
Part Number 03L906088DE Old Part Number with the new Part
03L906088GR.
Coil Light and Engine Light now OFF
Great News :-)
( Not to hard a job to do )
Newbie
Picture's of New & Old Part Number
( 03L906088FG does not fit this model my mistake )
The correct Part Number to fit is 03L906088GR as you can see it is longer at both ends giving a better fit :clap:
Exhaust Gas Temp Sender 03L906088DE Old Part Number - 03L906088GR New Part Number
15.   03L906088DE Removal
I have taken the car for many trips now and every time no longer have the coil light flashing and engine light on :sun:
Will now mark as solved.
Result Newbie.
:dance:
  • 4 years later...
So where is sensor 3 as its clearly only has 2 exhaust temperature sensors on the car. i can see the one near the turbo from the top.
  • 5 years later...
Result Newbie.
:dance:
Thanks for the info you’ve shared on this. It’s no doubt a distant memory now, but can you share info on how you managed to get to it? You state that it wasn’t a hard job, but I’m finding that access is is probably going to require taking the DPF out in order to get any tools in there. I’ve tried removing the air filter and reaching from that side, but I can’t get a spanner on to make any turns because of how the nut is aligned!
Even access from underneath looks like it might require removing the entire heat shield above the exhaust.
If you have any recollection of anything that would assist, I’d be extremely grateful.
Many thanks
