Skoda Yeti Right Headlight Xenon dead, foglight ok.
Hi.
I have a Skoda Yeti VIN: TMBLC75L6B6047470
The Right Headlight Xenon went dead, so I changed the Ballast unit --> Ok, Light's on
After a few months it died.
I have cheked all fuses. All ok.
The Workshop mailed me this:
Chassis Type: 7N0
Scan: 01 03 08 09 10 15 16 17 18 19 22 25 2E 37 42 44 46 52 55 56
          62 69 72 77
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
18-Aux. Heat -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
   Part No SW: 1K0 937 086 H    HW: 1K0 937 086 H
   Component: BCM PQ35  M   103 0615
   Revision: 00103 AD
   Coding: 40000AB8E00508C040080080110089E4437400AE726DA5605C8540000040
   Shop #: WSC 33361 790 00999
   VCID: 356B3F0D9C5A571
   Subsystem 1 - Part No: 5L1 955 119 A
   Component: SK356  26  0604
   Coding: 00F7B5
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 280211 05  54  0403
   Coding: 0730ED
1 Fault Found:
00927 - Terminal 30 (Right)
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 136
                    Mileage: 156169 km
                    Time Indication: 0
                    Date: 2111.14.27
                    Time: 11:24:03
             Freeze Frame:
                        Term 15 On
                    Voltage: 13.70 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
Is there anyway to read this and find what "module" is Faulty?
When I changed the Ballast in the headlight unit, do I have to alter any codes for this unit?
Will be glad for any help!
What fault code is logged on 55?
Tuesday,23,February,2016,10:11:16:32264
Auto
                Address 55: Xenon Range       Labels: 5M0-907-357-V2.lbl
Control Module Part Number: 5M0 907 357 C    HW: 5M0 907 357 C
  Component and/or Version: AFS-Steuergeraet    0148
           Software Coding: 3704091
            Work Shop Code: WSC 00773 218 181016
           Additional Info: 1K0941329   AFS-Lst.-Modul l    0008   1K0941329   AFS-Lst.-Modul r    0008
                      VCID: 346D020957204E9
4 Faults Found:
01042 - Control Module; Not Coded
            000 -  -  - MIL ON
             Freeze Frame:
                    Fault Status: 11100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 75
                    Time Indication: 0
             Freeze Frame:
                        Invalid
                        Invalid
                        Invalid
02657 - Power Output Stage for Right Headlight (J668); Not Coded
            000 -  -  - MIL ON
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 75
                    Time Indication: 0
             Freeze Frame:
                        Invalid
                        Invalid
                        Invalid
01539 - Headlights Not Adjusted
            005 - No or Incorrect Basic Setting / Adaptation - MIL ON
             Freeze Frame:
                    Fault Status: 11100101
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 75
                    Time Indication: 0
             Freeze Frame:
                        Invalid
                        Invalid
                        Invalid
00979 - Lamp for Low Beam; Right (M31)    (THIS LAMP IS NEW! Can this be a result of bad Ballast?)
            014 - Defective
             Freeze Frame:
                    Fault Status: 01101110
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 75
                    Mileage: 192808 km
                    Time Indication: 0
                    Date: 2119.14.14
                    Time: 10:05:37
             Freeze Frame:
                    Voltage: 11.79 V
                    Speed: 0.0 km/h
                        ABS 1
Hi
I replaced the "Power Output Stage for Right Headlight (J668)" (Ballast), did a reset.
And:
55-Xenon Range -- Status: OK 0000
Solved
