help with abs and big fronts and hopefully rear disk
Hi there hoping some one can help me out. I have a fun that's been fitted with abs and the 256mm fronts by me lol. Wondering if I can fit the rear disk conversion I have kicking about on the standard abs pump master cylinder set up. Or will I need to upgrade the pump and master cylinder. There is now no load valve and all brake pipes done all set up and tested stops quick. My other car felicia 1.4 16v has same fronts and lockup lol
Yes should be fine the abs ring should fit on the rear disk hub. The abs mastercylinder is the biggest available so shoukd be up to the job.
Ok thanks for this time to get the spanners out
