Removing metal panel on rear door
I want to removing be the metal panel behind the rear door card I have drilled out all the rivets and I need to release the window from the plastic clip anyone know the best way to do this??
  • Sponsor
Thread a suitable-sized screw into the hole in the centre of the inner cylinder, then pulll it out. Then thread a bigger screw into the remaining hole and pull the outer cylinder out. Haynes tells you the sizes, I think the smaller one might be M5?
I just pushed them out into the door then retrieved after it was off. although I did nearly forget and leave them there.
I'd go with Winos suggestion, especially when refitting as if you push it all the way through when refitting, you will have to remove the carrier again to retrieve.
The peg pops back in the window before installing and just push down.
You don't have to insert the peg back in with the regulator in place.
B5FF1A73-BD74-456D-8CF9-8B1CE1BE5A91_zps
 on the regulator there is a hole to put the peg through, meaning the reg pulls the window down, as otherwise surely you are relying on the window 'dropping' down albeit while resting on the peg? My rear windows did seem to easily 'drop' I had to push them down into the regulgtor even though I had wound it down a bit.
p.s- does the sound-deadening make much of a difference?
Edited by Thisday
The regulator clamp is open at the top. You slide the glass down and it snaps into place. That's the proper way to do it
FF856D44-6075-4BDF-9B61-0EDF0C7627DA_zps
Ahhh I'd never noticed that before! Thanks for the Pro-tip!
