1.4 mpi cooling system engine overheated for no reasons
  • Sponsor
No. Did you look at the linked photo?
  • Replies 66
  • Views 11.5k
  • Breezy_Pete
    Breezy_Pete
    But that high pressure oil is highly localised within the gasket, at precisely one hole where the oil goes up into the head, so you have to have the seal at that one hole fail for oil at higher pressu
  • I am thinking of the thermostat. They are made very badly.   I rebuild mine and  put in an ordinary thermostat. Its a mechanic job, so it is may be best to change if you have not?   The other ting
  • I burned or got all my oil in the coolant and this is why it overheated ? Makes sense. The oil sensor should be doing it's job though and tell me I have a low oil level.
My bad, it's only the rad and expansion tank which are shut off, the matrix is permanently in circuit.
  • Sponsor
:thumbup:
Glad you saw it i was about to take a pic of a new stat housing to show that..
Ok, so we finally agree that the heater matrix is always getting coolant flow, whether the thermostat is opened or closed. Is there any plausible explanation why it was blowing cold air when the engine was boiling ? Is there any possible way to test if the pump works as it should be without taking it apart ?
Edited by Alexandru
Heater matrix will go cold if the coolant is blown out of the system and the level drops too low, matrix is at the highest point in the system so fills with air first.
Ok well if you run the engine with the pressure cap off you should get flow through the small pipe into the expansion tank once it has warmed up.
It possibility air locked the heater once it started to boil but its looking like waterpump failure
Can I check it ? It's not expensive as a part, but still...as far as my mechanic told me, if it is not leaking, it's in good shape. Can it be a third situation ?
  • Sponsor
I thought everything was OK since the new thermostat went in?
It is perfect. I'm driving it daily, in all kind of traffic situations and on mostly all it's rpms. I was just being curious why it was blowing cold air and I'm getting concerned about the pump's health, that's all.
Edited by Alexandru
It's a fairly easy job to stick a new pump on if you're worried.
Then you are worrying over nothing. .
If its ok then its ok.
It probably just that when it boiled up it airlocked the heater. If its fine now then its fine. The water pump wont fix itself once broken
I can still hear water bubbling around the heater matrix after leaving the car parked over the night. It stops after about one mile or so.
Funny thing: after turning off the engine(after driving a few hours) I can hear a sound coming from the heater matrix (through the central vents) like it's depressurising or something.
What is wrong with it? It has a mind on it's own!
Edited by Alexandru
Yours has A/C doesn't it? Maybe the noise is from that?
A/C is usually turned off.
Edited by Alexandru
Ac is never off on these its always circulating some refrigerant and sounds like yours may be low
That's what I was thinking. Probably needs regassing.
