Puzzled
I have got a rear wobble almost like someone has the rear window open just not as loud.
So far i have replaced.
Tyres changed wheels too still same.
Both rear wheel bearing's
Disc's and pads
At a loss really can't think what else it can be,all bush'es are fine.
Any input what so ever please im all ears....mot was recent and it's done it since day 1 of owning it.
Bearing's were shot,very dry and noisy.
What condition are the trailing arm bushes in? They could cause vibration.
They look sound.recently changed id say before me.as the arm's glossy compared to the rest also stickers.
I had alignment done too.all is good.Hunter machine.
I go to a specific place because that's all they do.apart from fitting tyre's before tracking.
Balance weights could of fallen off or there could be flat spots on the tyres??
Does it on my winter wheels.just not as much because there's more rubber on my winters 17's instead of 18's.
Just to eliminate tyre's i had all 4 new.
Car had conti's i swapped them for Vredestein Ultrac sessanta.still the same.
So i though bearing's did them,same.
After a valet next day the rear brakes were rusty.and the right rear wheel sounded like it was warped disc.
So i gathered some more parts...one night it was really hot the wheel...so i thought id got it.
replaced the caliper and fitted brembo discs and genuine pads.
Still the same.
And everything been done.new pins boots grease sliders.
Im really lost.could it be suspension?
Next is the front,bearing's then brake's then driveshaft's don't really want to keep spending.but it's really annoying not knowing.and i want it sorted before i think about any more modification's.
Get a four wheel alignment first, are you the only driver? I recall having issues then found out mum kerbed my car in the snow and forgot to mention it! Tracking was way out.
I have already had it done.and it's the same as the 1 before.
Tyre wear also fine.
I'm going to wash it later and swap wheels over,don't hold any hope though.
It's almost like a buckled wheel. From about 30mph+
very faint wobble/rumble.
Done it since i have owned it.and hasn't got any worse or better.only when i put wheels with more rubber on.it was slightly less.
