airbag light on F/L VRS
HI All
           Just upgraded to a Seat Leon MFSW & Air bag from a standard VRS wheel. Its had a steering wheel, airbag,MFSW airbag loom, Hi- line steering wheel  controller all code & working except for when you press the horn the airbag light comes on !! I'm thinking it may need a clock spring
                                   Any help or pointers would greatly appreciated
        Paul
Ok, can you tell more about the seat leon wheel, is it a newer type as fitted to the Leon 2013+
Hi Ed
          the wheel is from a 2012 Leon  http://www.ebay.co.uk/itm/121886599032?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT with air bag from a 2011 http://www.ebay.co.uk/itm/272158572530?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT  & this loom http://ww.ebay.co.uk/itm/191804133426?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT. It all works, buttons on both sides, apart from the dammed :x  airbag light
                                          Paul
what fault is shown with vcds?
0588 - Airbag Igniter; Driver Side (N95): Upper Limit Exceeded
airbag wiring and mf wiring are not on the same circuit
open the yellow plug that fits onto the slip ring and take a picture of the pins that go into that plug
Thanks Ed
                    I'll pop the steering wheel of either tonight if not tomorrow morning
Hi Ed
         Have some images, when I took the airbag off yesterday I noticed that the double brown wire could possibly be hitting the base of the steering wheel when the horn was depressed so i swapped the blue & brown over ( they are on the same terminal. I also added some insulation on to the spade connections, just in case. So far its been no trouble just getting some strange look driving around hitting the horn !!! :D
                                              Paul
[/url]">http://DSC_0270_zpscffm5imp.jpg
[/url]">http://http://s48.photobucket.com/user/balders64/media/DSC_0271_zpsckxbbyoi.jpg.html'>DSC_0271_zpsckxbbyoi.jpg
